skid
VR6 Vag com coding help plz.
I occasional get what feels like a lose of fuel or misfire problem.
Did a Vag com on the car and got this code :
00537 - Lambda (Oxygen Sensor) Regulation
11-10 - Control Limit Not Reached - Intermittent
Readiness: N/A
Can anyone shed any light on this as Ross tech has no explanation for this.
Readiness: N/A
Googled the code and this came up.
http://wiki.ross-tech.com/wiki/index.php/00537
One of my cars used to lose power on left turns on a quarter tank or less, the pump mounts inside the swirl pot inside the tank had disintegrated allowing the pump to suck in air
Thanks Dox, as stated Ross tech does not come up with:
Readiness: N/A
It has upper and lower limits but not that.
My car had a full tank and it still did it so def not that!
