robrado974
Knocking and rubbing on the drivers side .
Really annoying as I’ve renewed all the underside parts other than the suspension. I don’t think it’s a top mount . Mainly it’s on full right lock , you can hear a rubbing noise , I’ve had a look on full lock but I can’t see anything touching . The wheel was hitting the anti roll bar a while back but I thought I’d sorted that . Sometimes when pulling away or reversing it clonks too .
Did you change the CV joints Rob? Worth making sure the inners CV joint bolts are tight to the cups. When the Wifes beemer had the clutch changed the garage didn't do the prop shaft bolts up properly and it knocked when pulling away. By the time I'd pulled the undertrays off to see what was going on, 2 had come out and were rattling around in there, and the rest were bent!
It could be Sean . I didn’t change them , but they were removed to get to other parts . Definitely worth checking as you say .
I had a internet knock/cracking noise from under side in reverse more so found that the front radiator support was not secure,(previous owner again)secured all the bolts,covered 71 miles all good so far
Love the Corrado at this time
Pretty sure this is steering/ suspension related bandit . I will have to book it in , it needs to go on a ramp really .
Are the drop links secure/intact?
I will get them checked , it’s all new under there, but something may have worked loose .
I replaced the front suspension brakes calipers,brake hoses,though l got it but still knocked
It all ready had new lower suspension arms ball joints top suspension mounts ect
Only when fitting the 40 mm splitter l found the bolts not very secure
This definitely sounds like a real clonk , like metal on metal .
Definitely check all sub frame bolts,front support for the radiator
The noise l had was a load crack but was interment
You may see a bit of rust around some bolts in
Yeah , I will be checking everything, every nut and bolt.
