isometrix 10 Posted April 21, 2018 Hi All, So I managed to get ahold of the original Premium Dolby Cassette for my 93 SLC to continue to bring it back to orginal ...but even though everything works the cassette will not "suck in" to the player. Tried pushing and didn't work. Checked and there isn't anything in it. I disassembled a junk yard one that I had and I believe the function is mechanical and pulls it in. Without power, it sticks the same way. Any ideas or is it just dead? Quote Share this post Link to post Share on other sites
fendervg 32 Posted April 21, 2018 Is it a Gamma IV unit? I have one and the load function broke as well. If you can get a spare, you could cannibalise it for parts or just get a working one. Unless you plan on using it to play cassettes or need to demo it at a show I wouldn't worry about. I use an MP3 adapter or a CD changer with it instead. It will be very difficult to find anywhere that repairs tape mechanisms at this stage and it will be difficult to source parts. Quote Share this post Link to post Share on other sites
isometrix 10 Posted April 21, 2018 Not the gamma- but the OEM NA. From Google: [ATTACH=CONFIG]92938[/ATTACH] Unfortunately, I picked it up to play cassettes Is that normal for the Gamma and other older units? I'll just have to keep looking. Thanks for your suggestion! Quote Share this post Link to post Share on other sites
fendervg 32 Posted April 21, 2018 Yeah, it's quite common - if you open it up you'll see that the load/eject mechanism is actually hellishly complicated - lots of little plastic levers, cogs and springs. They just seem to give up the ghost eventually due to old age. Best of luck with your search. Maybe there is a more recent unit that would still look OEM. Quote Share this post Link to post Share on other sites
