olly elworthy 0 Posted July 26, 2004 so then guys im thinking of changing the camshaft in my g60, have any of you got aftermarket cams fitted and if so what ones? :D Quote Share this post Link to post Share on other sites
scruffydubbers 0 Posted July 26, 2004 i've got a piper 285 in mine seems good but i have only ever driven with it in so cant compare it sorry. although it is very lumpy on idle. something to consider if it bothers you. its called a 285 but i think the duration is actually about a 266. one thing with force induction engines you dont want a cam to wild which has got overlap, otherwise the air that is being forced in will go straight out the exhaust valves. Quote Share this post Link to post Share on other sites
h100vw 0 Posted July 26, 2004 I have found that having a vernier pulley can eliminate a fair bit of lumpy tickover issues. My MK1 with Pack C head and TSR 103 (282 deg) cam hunted badly til I fitted the pulley and had it set up. Gavin Quote Share this post Link to post Share on other sites
G-Lader 0 Posted July 26, 2004 Think Ive seen somewhere (TSR site maybe?) that 260 or 270 degree suits the best normally......suppose it depends on what other mods have been carried out? Quote Share this post Link to post Share on other sites
Henny 0 Posted July 26, 2004 yup, standard cam in mine... with a G60 and lots of boost, sticking a wild cam in has this annoying habbit of blowing the boost straight out of the exhaust... :roll: :lol: Quote Share this post Link to post Share on other sites
olly elworthy 0 Posted July 26, 2004 does anyone have the figures for a std G60 camshaft? as in duration and lift? was wonedring how they compared to this cam,,, Duration:226/220, Lift:10.15 with a lobe centre angle of 108.5 Quote Share this post Link to post Share on other sites
olly elworthy 0 Posted July 26, 2004 am i right that a cam with 226/220 duration equates to 226+220=446, -180 =266 duration camshaft? Quote Share this post Link to post Share on other sites
24V Renshaw 0 Posted July 26, 2004 Standard cam is best on a G60. Any more lumpy cam will only move the power up the rev range, losing the best part of the G60 enigne, the low down power. J Quote Share this post Link to post Share on other sites
g-master 0 Posted July 26, 2004 :) defo standard :!: Quote Share this post Link to post Share on other sites
MelG60 0 Posted July 26, 2004 Standard? :lol: A Schrick 268/276 is the best cam for street use, very good idle and you will make good power up top. I placed about 10 of them and all owners were very pleased. Quote Share this post Link to post Share on other sites
BigTartanJudge 0 Posted July 26, 2004 I have to agree with MelG60 on this one, I have the same cam (Schrick 268/276) in mine and it's great, and you know the figures mine puts out :D Cheers, BigEastsideVWG60 Quote Share this post Link to post Share on other sites
Andy D 0 Posted July 26, 2004 Hi ya I fitted a piper fast road camshaft ( 260deg p/n G60BP270H Fast Road) to my Corrado G60 with a set of new lifts and a vernier pulley. I went for the fast road cam as this reduces the lumpy idle as the valve over lap is smaller and the power band kick in a lot low than the race cams. I notice a lot of difference, my car pulled through the gear a lot better and the power band was bigger especially in the top end of the rev range. The car seems to idle smoothly and starts up ok. :D Quote Share this post Link to post Share on other sites
kongo127 0 Posted July 26, 2004 I am thinking to change my G60 camshaft too. :-P There is the 260º symetric one. And there is the 268º/276º assymetric. These are the most common ones i think... What would be the differences between these cams running in the car? :? Quote Share this post Link to post Share on other sites
W3RKD 0 Posted July 26, 2004 Standard? :lol: A Schrick 268/276 is the best cam for street use, very good idle and you will make good power up top. I placed about 10 of them and all owners were very pleased. you are correct there mel :lol: but i do feel that with this cam it compremises low down pull as they seem to push the power quite a bit higher up the rev range. :lol: Quote Share this post Link to post Share on other sites
24V Renshaw 0 Posted July 26, 2004 Exactly, yes you will get more outright "power" if you fit a higher lift cam. All very good on the 1/4 mile, but in day to day driving I know exactly where I would rather have that power. AMD said the best one they ever fitted to a G60 was a 2.0L MK3 GTi 8v Cam, so for a cheap option to try it and see what you think, try one of them. I got one for £10, but never bothered fitting it as I love the low down power. Jay Quote Share this post Link to post Share on other sites
stevemac 0 Posted July 26, 2004 Piper 270 deg "fast road" cam & adjustable cam pulley sitting on my dining room table at the mo. Gonna slap 'em on when I get around to doing my valve stem seals in the near future. Quote Share this post Link to post Share on other sites
olly elworthy 0 Posted July 27, 2004 interesting views, I was thinking of using a cam from a different vw 8v engine,,, may just try it and see what its like at the weekend, ill let you all know how i get on,, :D Quote Share this post Link to post Share on other sites
MelG60 0 Posted July 27, 2004 I think the 2.0 8V cam is excactly the same as a standard G60 cam. That is true Darren, i tried a standard cam on my G60 (running 1.4 bar boost) and it was like driving a 150hp pd TDI :lol: Very nice if you drive a lot of miles. Although i like the 268/276 Schrick more, i made the 276hp with the Schrick. I am now running a 300/290 cam; lumpy idle and doesn't do much below 3000 rpm. Quote Share this post Link to post Share on other sites
olly elworthy 0 Posted July 28, 2004 was thinking of a PB 1.8 golf gti cam, been reccomended by a very well respected person in the vw trade so im gonna give it a try,,, :D Quote Share this post Link to post Share on other sites
bazgreener 0 Posted August 4, 2004 Be interested to see how it works Olly, i have a PB cam sat in my garage. Baz Quote Share this post Link to post Share on other sites
Trilidon 0 Posted August 4, 2004 260/268 or was it 268/260 whatever =P Quote Share this post Link to post Share on other sites
olly elworthy 0 Posted August 20, 2004 ive tried it and seems more revvy i.e. better between 5&6k, but i think ive lost a bit of torque, so will prob keep it in there for another day or so and then revert back to my good old G60 cam!! was worth a try i suppose,,,, :) Quote Share this post Link to post Share on other sites
Polo Classic 0 Posted September 3, 2004 I've just ordered a 264/274 with 11,2/11,5 mm lift and 112 ls for my brothers rado. Will be fun to see how it goes..... Quote Share this post Link to post Share on other sites
Sandy 0 Posted September 3, 2004 I have the Schrick 268/276 in mine and it feels great Quote Share this post Link to post Share on other sites
