tonedef 10 Posted July 22, 2018 As title, mine seems to work for a day and then give up the ghost. Would like to try another one and see if that fixes it. Quote Share this post Link to post Share on other sites
Mystic Blue VR 10 Posted July 22, 2018 Very simple inside. One bulb, three diodes & one resistor & I think all of the boards may be the same. One of the maintenance lads at work checked mine & found a duff diode. A few pence to replace he said & simple to do. if you know what your doing! Quote Share this post Link to post Share on other sites
tonedef 10 Posted July 22, 2018 Very simple inside. One bulb, three diodes & one resistor & I think all of the boards may be the same. One of the maintenance lads at work checked mine & found a duff diode. A few pence to replace he said & simple to do. if you know what your doing! It always looks like there’s nothing much inside it, it falls to pieces every time I take it out after all! I’ll go in there with my multimeter and see if I can figure it out then. Cheers Quote Share this post Link to post Share on other sites
Philly-R6 2 Posted July 24, 2018 There is one on ebay for £60 - ending 22nd Aug 2018: https://www.ebay.co.uk/itm/Corrado-ABS-warning-light-535-919-235-BA/323362706757 Quote Share this post Link to post Share on other sites
Dox 31 Posted July 25, 2018 There’s different part numbers depending on the wiring plug configuration, you need to quote the the last two letters of the part number for an exact match. Quote Share this post Link to post Share on other sites
tonedef 10 Posted July 25, 2018 There is one on ebay for £60 - ending 22nd Aug 2018: https://www.ebay.co.uk/itm/Corrado-ABS-warning-light-535-919-235-BA/323362706757 Looks like I missed it, no longer available! Quote Share this post Link to post Share on other sites
