patrick p
Pcv valve
I think it's called the pcv valve on back of cylinder head which connects the plastic housing onto mafs sensor and air filter I think oe no is 7m0128101 cheers pat
If it's on a VR, you can bypass it without any trouble - do a search and you'll find plenty of info. Replacements are available from VW, on eBay and also from Ford (much cheaper) as the part was also used on the VR6 Galaxy.
You can fit an oil catch can with appropriate hoses in place of it. I've got all the bits, just need to find the time to do it!
