Jamie 1 Posted September 27, 2018 The fan speeds all seem to work, but are in the wrong order - something like number 1 is speed 3, 2 is 1, 3 is 4 and 4 is 2! Any ideas what could be causing this? I’m thinking it’s the switch on the dash but before I shell out for a new heater control panel, anything else it could be? Quote Share this post Link to post Share on other sites
dragon green 6 Posted September 27, 2018 Sounds like it's time to get the local priest out for an exorcism ! 😀 Early or late interior? Does sound like a switch Quote Share this post Link to post Share on other sites
vw rule 19 Posted September 27, 2018 Could possibly be your fan resistor, as this communicates with the fan motor to tell it when to operate at certain speeds, once the desired speed has been selected from fan switch so to speak. The fan resistors can sometimes do that. Fan switch unit is roughly £200.00 Through VW Heritage for later type 1992 to 1995 The early type switch unit is a lot cheaper. Fan resistor is roughly £10 to £12 From Ebay or possibly Heritage. Fan motor is roughly £45 to £55 From Ebay or again possibly Heritage. Hope this helps Si Quote Share this post Link to post Share on other sites
Jamie 1 Posted September 27, 2018 Nice one cheers mate. I’ll start at the cheap end and go from there. Quote Share this post Link to post Share on other sites
fla 9 Posted September 27, 2018 Take the resistors out from the top left hand corner of the dash just next to the dash tweeter. It may be that they're in contact with each other. So all you need to domos space them out. If they're broken off, just trim the end off and refit to the resistor panel. I think.i posted something on it a few years back Quote Share this post Link to post Share on other sites
Jamie 1 Posted September 27, 2018 Don’t suppose you’ve got a link to your thread have you Hasan please? Quote Share this post Link to post Share on other sites
fla 9 Posted September 27, 2018 Just been looking for it but can't seem to find any images. I should still have them on my computer so will try and post up asap for you. But essentially if you remove the glove box you'll see a harness of generally yellow cables going across towards the lhs tweeter. These go to the resistors. There are two (very awkward) screws holding the panel into the top of the dash. When you rekove it you'll see what looks like springs of different thickness. These are the fan speed resistors. Quote Share this post Link to post Share on other sites
fla 9 Posted September 27, 2018 http://the-corrado.net/showthread.php?65049-Air-con-resistor-Where-to-buy Looks like images here Quote Share this post Link to post Share on other sites
Jamie 1 Posted September 28, 2018 Brilliant thanks Hasan. My car has air con so am I right in thinking I’ll have that spring looking thing instead of a diode pack on the blower motor? Quote Share this post Link to post Share on other sites
fla 9 Posted September 28, 2018 yes. You'll also likely have a different thermal fuse (made by/for Lancia!) I've attached the pics i took when i replaced the thermal fuse in my car - might be of use. The screw nearer to the dash is a real pain! You'll need a swivel head angled driver - one that fits into a ratchet spanner. And patience... Quote Share this post Link to post Share on other sites
Jamie 1 Posted September 28, 2018 Excellent cheers mate. How do I open the pics? I can see “attached thumbnails” but can’t click on it or see them Quote Share this post Link to post Share on other sites
a_riot 0 Posted September 28, 2018 If it isn't the resistor, you might want to take a look at the copper contact ring under the fan speed dial, assuming you have the later interior. That can get bent and then you may see odd behavior when turning the dial. Usually you'll just lose speeds when that happens, not mix up speeds, but if the thin copper contact ring gets warped or shifts position, that could occur I guess. First try just pushing on the dial and see if that changes anything, and then take a look inside by removing the dial. The small copper contact that is moved along the ring when you spin the dial can get oxidized, bent, or develop wear spots, and usually a good cleaning, straightening out and repositioning will fix it. You'll see what I mean once you open it up. I had only speed 4 and so took it all apart and redid it and now have all 4 speeds, and the dial feels better to turn to boot. Quote Share this post Link to post Share on other sites
Jamie 1 Posted September 29, 2018 First port of call was the switch but thanks for your reply mate Quote Share this post Link to post Share on other sites
