robrado974 1 Posted November 21, 2018 (edited) Last year I bought a carpet from Newton commercial and the delux underlay from Heritage. I also bought the closed cell sticky product that goes straight on the floor pan . For starters the deluxe underlay could not be used as its too bulky, so I had to change it to one layer . The carpet was hard to fit as it’s thicker than the Oem carpet and not very forgiving over the humps and moulds of the floor pan . It also joins in the middle of the car so the join can be seen . Can anyone tell me as I can’t remember, did our cars have underlay under the seats ?, or is it just the carpet?. As it is at the moment I have underlay under the seats which makes it hard to slide the seat from outside the car eg for hoovering . I cannot fit the seat runner covers either, it’s just too tight. If I can’t sort this I will be looking for a second hand Oem carpet.Any info is much appreciated as usual.kind regards, Rob Edited November 21, 2018 by robrado974 Quote Share this post Link to post Share on other sites
vw rule 19 Posted November 22, 2018 Rob I've got tomorrow off work plus my Corrado is in bits, so I can have a look at my carpet and confirm if it's got any underlay or not. I don't recall seeing any underlay under my carpet, but like I say I'll let you know tomorrow. Si Quote Share this post Link to post Share on other sites
fla 9 Posted November 22, 2018 Rob i think there was underlay under the front seats but not the back. So the floorpan was covered with felt and a mass layer up to the edge below the back seats, including the handbrake tunnel Quote Share this post Link to post Share on other sites
robrado974 1 Posted November 22, 2018 Thanks Si and Hasan . I think this is where I have gone wrong, or not so to speak. Around 18 months back I had a membrane leak , we all know that once the sound deadening gets wet it stays wet and is a pig to dry out .So I bought the new underlay which is thicker than the Oem stuff . Hence now the reason for the info. I can’t even fit the plastic part on that stops the seat from rocking , not that it does now anyway because it’s tight to the carpet. You can see a mark on the carpet , behind the drivers seat where I’ve pushed the seat back ,this shows you how tight it is . Quote Share this post Link to post Share on other sites
