Dub Style
What has been done to these arches?
i just lov the way that car is sat on them wheels..............wot u think has been done here as the arches dont look original
the fronts look stretched a bit
there was a blue C on the cover of PVW a while back and that had stretched arches IIRC think it was taken to germany to get done
They've been pulled and rolled same as my C. I've gone 2" inch wider at the rear and 1.5" at the front.
A20 LEE, have u got any pics of ur car where u can see the arches, also was this a big task
Yep its a massive task and you need to buy your wheels first so the arch can be shaped correctly and will cost over £1k to do which isn't bad when you consider four corners of the car will be painted.
