Stone0311
Battery Ground
Hi All,
Having relocated my battery to the boot to make way for the FMIC and also replaced/smoothed the battery tray as it was rotten, I now need to create a new main ground/earth in the bay - any tips or guidance on method?
My plan was to drill a new hole in the chassis leg below the old tray location and and tap it for a suitable bolt, providing the paint is removed for a good contact?
For the connection in the boot from the battery i was considering using the threaded stud from the old spare wheel or do the same as above in the boot floor near the chassis.
Any input appreciated, want to close this out before i lift the engine back in and loose access. Thanks
Any place on the main chassis will do for a new earth point previding its a clean rust free area.
