Keyo 49 Posted December 24, 2019 (edited) Interesting this is a VW original OE RHD extremely rare pod cluster that fits early cars. The gauges are not original but good quality. The battery gauge has been swapped out for a boost gauge so ideal for an early car with turbo upgrade. I think Sprinter had made some for reproduction ones for LHD but not RHD so extremely rare part. Pod is Number 7 on diagram http://www.oemepc.com/vw/part_single...4/lang/e#sec_7 You can still buy the two missing bungs from classics Part number 535867842A 4FB https://www.volkswagen-classic-parts...en-dd06a7.html Pod and gauges https://www.ebay.co.uk/itm/Vw-Corrad...97.m4902.l9144 Good buy for someone with an early car with a turbo or someone willing to put a battery gauge back in how it came from factory. You can still get the original VDO gauges in regards to the part numbers . So would be a complete stock unit. No 22 + 23 on diagram. http://www.oemepc.com/vw/part_single.../lang/e#sec_23 Battery Part number 321919531A https://www.justkampers.com/321-919-...olt-range.html Oil part number 155919551 https://www.justkampers.com/155-919-...bar-range.html I would be all over this if I had an early model as truly rare !!! Edited December 24, 2019 by Keyo Quote Share this post Link to post Share on other sites
fendervg 33 Posted December 24, 2019 Very nice, and rare to find in RHD - but pricey. There were a few aftermarket versions of the panel available as far as I remember. Personally I'm not gone on the silver gauge trim - the original gauges are just standard black VDO ones with green backlight in instead of orange - still available new, and common on "sporty" Golfs, Scirocos and Audis from the 80s - you might just need to swap over the bulbs. With a twin pole pressure sender from an Audi Coupe you could get the whole lot from a breaker apart from the holder itself. Quote Share this post Link to post Share on other sites
Keyo 49 Posted December 24, 2019 Yes you would have to buy the VDO gauges that are black to make it stock, none the less a rare item. The newer POD models look so much better though !!! Quote Share this post Link to post Share on other sites
