mavis1979
Heater control
Sorry if this has been asked a thousand times before but I’ve only just bought a Corrado after a 18 year break and 18 years ago everything worked.
My heater control doesn’t work on any setting and I can’t see. It seems to be slightly warm as after a while it SLOWLY demists but I’d like it working
Any help much appreciated
You need to check the fuse first and then see what’s getting power. If it was the thermo fuse on the fan that went it would work but only on speed four. So I’d say fuse then the actual switch to test next. In the switch is a copper tab that may need tweaking slightly.
Something wrong there then, I’d put a proper fuse in and see if there is power to the switch.
if the switch is goosed you can get one of these mk3 controllers, the switch is basically the same just upside down on the other side. I used one to fix mine.
https://www.heritagepartscentre.com/uk/1h0820045c-fresh-air-and-heater-controls.html
  • Thanks 1
