blottje 0 Posted April 1, 2021 Bummed as my metal sunroof has finally succumbed to the inevitable failure of 90's vintage crappy cast metal parts. In my case I need a Left Cable Assembly 1h0898015a (not Passat part 1h0898015 which will not work properly with metal sunroof). If you have one for me, I would greatly appreciate the contact. Quote Share this post Link to post Share on other sites
blottje 0 Posted April 25, 2021 I have found part, thank you. Quote Share this post Link to post Share on other sites
Cressa 44 Posted April 25, 2021 Well done in getting it sorted. Make sure you clean all the rails out and lube with the correct grease, otherwise the same may happen again.... Quote Share this post Link to post Share on other sites
Paul33 0 Posted January 20, 2022 Hi I've got the exact issue, where did you get part from and did you do the fix by yourself? Quote Share this post Link to post Share on other sites
fendervg 33 Posted January 20, 2022 Check the FB Corrado groups - one of the guys one there remade the parts on both sides as far as I know - hopefully someone on here has the exact details. The VAG repair kits themselves that come with new cables are no longer available, although they do come up on the secondary market every once in a while. Quote Share this post Link to post Share on other sites
Cressa 44 Posted January 20, 2022 Someone has remanufactured these parts recently. Who was it? Quote Share this post Link to post Share on other sites
Cressa 44 Posted January 20, 2022 Just now, fendervg said: Check the FB Corrado groups - one of the guys one there remade the parts on both sides as far as I know - hopefully someone on here has the exact details. The VAG repair kits themselves that come with new cables are no longer available, although they do come up on the secondary market every once in a while. You beat me to it by seconds.... 😊😂 Quote Share this post Link to post Share on other sites
Cressa 44 Posted January 21, 2022 (edited) https://corradofarmparts.com/collections/sun-roof-repair Here we go Out of stock at the moment. Not cheap but what other choice is there... Everyone that has a working sunroof should remove it, strip it down, clean and re-grease as a matter of a 25yr+ service now Edited January 21, 2022 by Cressa Spell check.. Quote Share this post Link to post Share on other sites
g0ldf1ng3r 15 Posted January 21, 2022 4 hours ago, Cressa said: Everyone that has a working sunroof should remove it, strip it down, clean and re-grease as a matter of a 25yr+ service now precisely what is happening on my VR atm - hopefully it will revive it Quote Share this post Link to post Share on other sites
Cressa 44 Posted January 21, 2022 4 hours ago, g0ldf1ng3r said: precisely what is happening on my VR atm - hopefully it will revive it A clean and a straight swap mk3 golf motor made mine fresh have legs again 👍 Quote Share this post Link to post Share on other sites
g0ldf1ng3r 15 Posted January 24, 2022 On 1/21/2022 at 5:21 PM, Cressa said: A clean and a straight swap mk3 golf motor made mine fresh have legs again 👍 thanks cressa IIIRC i have already changed the motor for a better second hand one a few years ago it used to move ok on manual but motor struggled so am hoping it is just gunked up & the tension cut off is not letting the motor strain Quote Share this post Link to post Share on other sites
Cressa 44 Posted January 24, 2022 8 hours ago, g0ldf1ng3r said: thanks cressa IIIRC i have already changed the motor for a better second hand one a few years ago it used to move ok on manual but motor struggled so am hoping it is just gunked up & the tension cut off is not letting the motor strain Good luck with it mate. Pain of a job if it all has to come out... 😳 Quote Share this post Link to post Share on other sites
g0ldf1ng3r 15 Posted January 25, 2022 23 hours ago, Cressa said: Good luck with it mate. Pain of a job if it all has to come out... 😳 the cartridge is being removed & completely stripped m8 took the opportunity to have the head liner etc retrimmed too Quote Share this post Link to post Share on other sites
Florin Ilie 0 Posted August 23, 2023 Hi guys, is there anyone on the forum who knows where to get parts for the sunroof? Quote Share this post Link to post Share on other sites
