_Matt_
Spare keys - where from ?
Hi,
Where can we get spare keys with I transponder coded to the car? I do have an aftermarket Cat1 alarm but don't know if they by-passed the factory immob.
Cheers
Matt
Remove the fuse for the rear spoiler, the immobilisers shares the same fuse , if the car won’t start the immobiliser is still live
Only ever had one done years ago at Vw, but believe loads of key people able to do them now
VCDS can code the transponders to the immobiliser (if you have the passcode for the immobiliser): Immobilizer 1 - Ross-Tech Wiki
(You can read the immobiliser passcode using vag-tacho, if you don't have it)
I can do this with you - if you are around Manchester...
