_Matt_ 26 Posted May 14, 2021 Hi, Where can we get spare keys with I transponder coded to the car? I do have an aftermarket Cat1 alarm but don't know if they by-passed the factory immob. Cheers Matt Quote Share this post Link to post Share on other sites
Dox 22 Posted May 14, 2021 Remove the fuse for the rear spoiler, the immobilisers shares the same fuse , if the car won’t start the immobiliser is still live Quote Share this post Link to post Share on other sites
_Matt_ 26 Posted May 14, 2021 Clever! Cheers Matt Quote Share this post Link to post Share on other sites
Cressa 44 Posted May 14, 2021 Only ever had one done years ago at Vw, but believe loads of key people able to do them now Quote Share this post Link to post Share on other sites
Philly-R6 0 Posted May 15, 2021 VCDS can code the transponders to the immobiliser (if you have the passcode for the immobiliser): Immobilizer 1 - Ross-Tech Wiki (You can read the immobiliser passcode using vag-tacho, if you don't have it) I can do this with you - if you are around Manchester... Quote Share this post Link to post Share on other sites
