fla 9 Posted June 12, 2021 Just beginning to tidy the car up a bit and was wondering what the correct method of attaching the bottom arm of the rear door cards should be to prevent them inadvertently getting broken off. I usually try and force the door trim back slightly to trap them under, but this means the rubber then sits above the door card but under the trim. Welcome any suggestions or indeed any pics of your installs. Hasan Quote Share this post Link to post Share on other sites
Cressa 45 Posted June 13, 2021 This is how mine sit Quote Share this post Link to post Share on other sites
_Matt_ 32 Posted June 14, 2021 I'm glad you posted both as put mine back in this weekend and didn't think the 1 inch gap looked right on mine. Maybe I have the kick trims on the wrong side as assume the kick trim holds the bottom of the door card too? Sent from my SM-G960F using Tapatalk Quote Share this post Link to post Share on other sites
fla 9 Posted June 14, 2021 On 6/14/2021 at 8:27 AM, MJA said: I'm glad you posted both as put mine back in this weekend and didn't think the 1 inch gap looked right on mine. Maybe I have the kick trims on the wrong side as assume the kick trim holds the bottom of the door card too? Sent from my SM-G960F using Tapatalk Yes i think so. One of mine has broken at the weakest point so will need repairing at some stage. Btw, those door scuff plates look different - any more pics of those? Quote Share this post Link to post Share on other sites
Cressa 45 Posted June 14, 2021 Not the best of pictures... and mine may be wrong !! But they hold it al togethet Quote Share this post Link to post Share on other sites
_Matt_ 32 Posted June 14, 2021 Thanks Cressa I will re do mine.Fla here they are. I got them off ebay. I've picked up the embossed corrado black ones so might take them off although I fear I will pull paint off so may not.And one of the car in its half put back together state. Its been back to a shell (engine didnt come out) and I mostly spent time sorting the underside.Sent from my SM-G960F using Tapatalk Quote Share this post Link to post Share on other sites
ben_wooduk 0 Posted June 14, 2021 On 6/14/2021 at 9:30 AM, MJA said: Thanks Cressa I will re do mine. Fla here they are. I got them off ebay. I've picked up the embossed corrado black ones so might take them off although I fear I will pull paint off so may not. And one of the car in its half put back together state. Its been back to a shell (engine didnt come out) and I mostly spent time sorting the underside. Sent from my SM-G960F using Tapatalk You've got the wheels on!! 😁 Quote Share this post Link to post Share on other sites
_Matt_ 32 Posted June 14, 2021 On 6/14/2021 at 10:19 AM, ben_wooduk said: You've got the wheels on!! 😁 haha yes good spot! They are a perfect proportion of the Corrado. Quote Share this post Link to post Share on other sites
