Popeye775 16 Posted August 17, 2021 Hey all, As some of you know I have a corrado G60 with a recently swapped 2.0L bottom end. I have some AFR readings that I was just curious if anybody could confirm that they are ok ranges. I took my Corrado on a cruise today and between 2k-3k RPM crossing the AFR would stay between 14.5-15.8. Do these seem like ok numbers? Heres the specs for my G60: 68mm pulley267 cam2.0L bottom end30lb injectors3.5 bar pressure regulatorISV RerouteStage 3 tune from BBMRebuilt G-LadderCO Pot set @ 450 ohm Any sort of insight would be great. Thanks guys Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
1xshaunx1 27 Posted August 22, 2021 It’s a bit like in the film Marathon Man when the White Angel asks “is it safe”. what does it mean, what’s the right answer 🤣😂😝 Quote Share this post Link to post Share on other sites
Dox 28 Posted August 23, 2021 petrol engine stoichiometric ratio Have a google around with the above, the ratio / reading will alter dependant on load, cruising with light throttle will give around 14:1 (14 parts air to 1 part fuel), where as aggressively climbing a steep hill will need a much higher fuel ratio. Quote Share this post Link to post Share on other sites
