VR6Knight 0 Posted October 30, 2021 Hey Everyone! Newbie here! I was worried nobody talked about these cars anymore, glad I found this place! I own 3 Corrados, all purchased this summer. I went Rado Crazy haha! Really scary noise coming from the cooling fan from my 92' VR6, I took a vid, trying to find out how to post! VR6Knight Quote Share this post Link to post Share on other sites
fendervg 33 Posted October 30, 2021 Approved and welcome to the forum. Could be that it's running at Stage 3 all the time, in which case your radiator switch might need replacing. Could also be a knackered bearing in the motor or something catching on the fan blades - both of which would need to be checked out fairly quickly as it could be wiring that's getting caught. The best place to start for VR cooling and fan related issues is this thread here: It breaks down how it all works, the different sensors and when they should cut in. Quote Share this post Link to post Share on other sites
Cressa 46 Posted October 31, 2021 15 hours ago, fendervg said: Approved and welcome to the forum. Could be that it's running at Stage 3 all the time, in which case your radiator switch might need replacing. Could also be a knackered bearing in the motor or something catching on the fan blades - both of which would need to be checked out fairly quickly as it could be wiring that's getting caught. The best place to start for VR cooling and fan related issues is this thread here: It breaks down how it all works, the different sensors and when they should cut in. Check that the fan blades aren't catching the frame as that can sound horrendous when running Quote Share this post Link to post Share on other sites
