Hutty 10 Posted November 15, 2021 Proving difficult to find this. It's the PCV valve that I need but I understand it is only available along with the full intake hose assembly. Quote Share this post Link to post Share on other sites
fendervg 24 Posted November 15, 2021 You can get it from Ford - check out a parts diagram for a Galaxy VR6, you may even be able to get the whole unit if needed. The PCV valve us nothing special, just some gauze with a flap, if you can get the right size for the hoses, there may even be other ones that will work. Quote Share this post Link to post Share on other sites
Hutty 10 Posted November 15, 2021 1 hour ago, fendervg said: You can get it from Ford - check out a parts diagram for a Galaxy VR6, you may even be able to get the whole unit if needed. The PCV valve us nothing special, just some gauze with a flap, if you can get the right size for the hoses, there may even be other ones that will work. Thanks. I contacted VW who said that the part was made obsolete in 2014. Didn't contact Ford because I've been told that they are charging silly money for them now. I've managed to source one from Ebay so hopefully that will sort the problem. Quote Share this post Link to post Share on other sites
