STORM 2 0 Posted May 23, 2022 Hi anyone know the best option to source a new sunroof seal. - just noticed a flood in the drivers footwell ? Regards Quote Share this post Link to post Share on other sites
_Matt_ 32 Posted May 23, 2022 Probs best to check your door membranes first (door card off job). The Sunroof seal is supposed to leak water into the drip tray which is then sent out via the sunroof drains. They may well be blocked if your door membranes are good and will be another place to check. Quote Share this post Link to post Share on other sites
g0ldf1ng3r 16 Posted May 23, 2022 you can normally tell whether the water is getting in from above or below by looking for the kinda of snail trail lines it leaves if right front roof drain is blocked there will likely be a trail mark down the pillar & then down the side of the dash section i would then inspect door membranes if you cant see any trails if im honest, it is probably worth checking both & roof drain pipes are easy as just need blowing out with an air line FYI if a late model there is a hidden small screw behind the factory door speaker cover 😉 Quote Share this post Link to post Share on other sites
Cressa 44 Posted May 23, 2022 As above and get the hosepipe out to see if it helps Quote Share this post Link to post Share on other sites
STORM 2 0 Posted May 30, 2022 Thanks for that , I’ll take it apart this week and see what’s what Quote Share this post Link to post Share on other sites
