ger040 3 Posted November 8, 2022 I am currently trying to repair a butchered wiring loom and need to remove terminals from conn blocks I bought a cheap key set off ebay and after approx 2 hrs i managed to remove 1 terminal Is there anything out there better? Quote Share this post Link to post Share on other sites
fendervg 33 Posted November 8, 2022 They look nasty - you can actually use a fine tweezers or a large paperclip cut to a U shape. The good tools are a bit pricey: https://www.lasertools.co.uk/Product/7293/Connector-and-Terminal-Removal-Kit bust something like this will be better than what you have: https://www.ebay.co.uk/itm/133095877729?hash=item1efd21ec61:g:mygAAOSwph1dE0ge If you are doing a complete loom, it's worth investing in a small and large version of this: https://www.kufatec.com/en/accessories-spare-parts/tools/pin-removal-tool-small-pins-35496 Quote Share this post Link to post Share on other sites
ger040 3 Posted November 8, 2022 1 hour ago, fendervg said: They look nasty - you can actually use a fine tweezers or a large paperclip cut to a U shape. The good tools are a bit pricey: https://www.lasertools.co.uk/Product/7293/Connector-and-Terminal-Removal-Kit bust something like this will be better than what you have: https://www.ebay.co.uk/itm/133095877729?hash=item1efd21ec61:g:mygAAOSwph1dE0ge If you are doing a complete loom, it's worth investing in a small and large version of this: https://www.kufatec.com/en/accessories-spare-parts/tools/pin-removal-tool-small-pins-35496 Thanks Fendervg I have ordered the second one - yellow items and see what turns up On ebay thousands of items are listed and to be honest i just ordered one of the cheaper items as i only need to replace a couple of connectors Thanks again Quote Share this post Link to post Share on other sites
_Matt_ 32 Posted November 9, 2022 Me too - thanks fen (ordered the yellow ones) as also struggled like you ger040 for hours with the same gear as you had the last time I did a repair. Quote Share this post Link to post Share on other sites
