fendervg 33 Posted June 19, 2023 Hi all - just looking for some help and maybe pictures if possible - I'm in the middle of refubing my front wiper linkage, and forgot to make note of how the washers and spacers mount on the spindle as they go through the bulkhead. So I have: - a large metal washer - a black plastic cup spacer - a large nut So the nut obviously is the last part to go on, but a bit confused as to the spacer and the other washer - guessing that the spacer sits with the flat part up on the spindle, this mates up to the bulkhead, and then the washer and nut on the other side? Many thanks. Quote Share this post Link to post Share on other sites
_Matt_ 32 Posted June 19, 2023 Hi Fen, is this any good: Quote Share this post Link to post Share on other sites
fendervg 33 Posted June 19, 2023 (edited) Thanks for that - so it looks like the steel washer sits on the four shoulders of the spindle, then the plastic spacer, flat side to the washer and the lock nut on the outside. Will give that a go. Many thanks for the photos. Edited June 20, 2023 by fendervg Quote Share this post Link to post Share on other sites
fendervg 33 Posted June 20, 2023 (edited) Correction - there is also a rubber grommet that sits on the hole in the bulkhead - so the metal washer goes on the spindle, then the spindle is inserted from below through the grommet, then the spacer, sits around the spindle but in the grommet from the outside, flat side out, then the lock nut. You can see it in the second picture, the flat part the same colour as the lock but is the flat side of the spacer. Edited June 20, 2023 by fendervg Quote Share this post Link to post Share on other sites
_Matt_ 32 Posted June 20, 2023 Nice one Fen, must admist never taken it apart but good to see it documented as no doubt will have to. Q how much play should there be on the wiper arms in there rest position? Mine have a good 2cm of slop. Quote Share this post Link to post Share on other sites
oneohtwo 8 Posted June 25, 2023 I've done this a lot recently, but mine doesn't have the rubber grommet, just the metal washer and the plastic spacer. Might have to look into that, but otherwise yes the order is correct. I've always felt it seems an odd design, because there's not a lot actually clamping it to the bulkhead - perhaps the rubber grommet is key. I don't think there should be much slop in the wipers at all - your 2 cm of slop is likely due to the worn nylon bushes on the flat link arm that goes between the wiper motor and the wiper mechanism. I have been experimenting with potential replacements, and the prototypes on mine have removed the slop completely. The wipers can be positioned correctly, and will no longer hit the scuttle trim, or the side of the windscreen. I have just received a latest batch of bushes so will see how these go. There is another thread in here where I have documented my attempts. Quote Share this post Link to post Share on other sites
fendervg 33 Posted June 25, 2023 Looking forward to any develpments with those new bushes of yours seeing as the parts are now NLA. Great to see stuff like that going on. I didn't realise there were any rubber grommets there at all either, until I checked the lip of the aperature - mine were still in there. I think they are still available as they are a standard part, and probably worth replacing to make for a more secure mounting. Quote Share this post Link to post Share on other sites
oneohtwo 8 Posted July 9, 2023 I have double checked, and actually I do have the grommits - they are clipped into the body work flange, so don't come off with the spindle which is why I couldn't remember them. I still think it's a bit of an odd mounting, and don't hundred percent see how it is clamped in the hole. The spindle just seems to be clamped to itself! There doesn't seem to really be much on the underside to stop it pulling through the hole... I presume the metal washer is just large enough. I have also noticed even with the metal washer the 4 lugs on the spindle tend to deform the plastic spacer. On the bushes, I have made some good progress with these, if you check the other thread! Quote Share this post Link to post Share on other sites
fendervg 33 Posted July 19, 2023 (edited) Have all replacement parts now, so here is a definitive (I think): From left to right: 1. Wiper arm nut 2. Wiper arm washer 3. Spindle lock nut 4. Plastic spacer (sits inside the gromment) 5. Rubber grommet (sits in hole for spindle in cavity) 6. Support washer (sits on fours support grooves/shoulders on lower spindle) The key thing is the gromet, the support washer then sits snug from the inside of the panel, and the plastic spacer is inserted from the outside and sits inside the grommet, the black spindle lock nut then tightens down directly on to the flast face of the plastic spacer. Here are the part#s if anyone needs them - all still available from Classics and aftermarket, fleaBay etc. sPINDLE NUT - 7D0955243 SPACER RING - 867955251 GROMMET - N90465501 COVER CAP - 1J0955205A 9B9 CRANK ARM - 535955121 COVER DISC - 481955255 WASHER - N01155811 NUT - N0111513 SPACER - 111955641 Edited July 19, 2023 by fendervg Quote Share this post Link to post Share on other sites
oneohtwo 8 Posted July 20, 2023 Good work, that looks it, although I notice I don't have a washer for the wiper arm. One thing I have noticed is how easily the metal washer that goes underneath the rubber grommet deforms. It's pretty thin and only bearing against the four shoulders of the spindle and against soft materials on the other side, so if you over tighten it deforms. I'm not sure what the torque settings are for the this but previously I had been really tightening these up to try and take out some of the slop (until I realised it was the link arm). As a result these washers were pretty wavy - I straightened them out and now just nip the nuts up until they are a bit firm, but no more. I was tempted to replace these with a thicker washer, but didn't have any of the right size spare. Quote Share this post Link to post Share on other sites
fendervg 33 Posted July 20, 2023 Yeah, my old ones are quite worn and deformed - you could probably double them up, but they are an odd size to get hold of. Quote Share this post Link to post Share on other sites
James. 9 Posted July 20, 2023 On 7/20/2023 at 9:00 AM, oneohtwo said: I'm not sure what the torque settings are for the this Not much. You'll need a low range torque wrench. 7nm for the assembly to wiper shaft 15nm for the wiper arm to wiper shaft Quote Share this post Link to post Share on other sites
_Matt_ 32 Posted May 7, 2024 Just catching up on this topic as will need to do soon. Can you remove the wiper assembly without removing the black plastic scuttle panels? I have a lot of play in the small gold arm but probably best to remove the whole lot and refresh what is needed. Video attached to show 20240507_141818.mp4Fetching info... Quote Share this post Link to post Share on other sites
oneohtwo 8 Posted May 10, 2024 You can, yes. If you pop the wipers off and undo the larger spindle nut, the spindles will just drop through. Nothing is connected to the plastic trim. It takes a bit of wiggling to get the wiper mech out from under the scuttle, but that's the same whether the plastic trim is on or not. I can't remember if you picked up one of my sets of wiper bushes, but that's exactly the sort of play in the connecting rod that they will get rid of. Quote Share this post Link to post Share on other sites
_Matt_ 32 Posted May 10, 2024 I do have your washer bundle but also have nos short and long arms too. Can never have too many spares 😄 Quote Share this post Link to post Share on other sites
fendervg 33 Posted May 11, 2024 Yep, it’s possible. Access is easier with them off, but you will likely break them or crack the windscreen trying to get them unstuck. I’ve replaced mine with an SWG one piece panel. Don’t forget to u do the bolt on the bracket to the firewall near the wiper motor. It’s well nigh impossible to get the motor off with the wiper mech in place. Quote Share this post Link to post Share on other sites
