Stone0311
Air rotary insert bar
Hi all,
Looking at some options for remanufacture of the support bar that directs the fins on the rotary insert for air, all of mine seem to be deteriorating faster than anything else and considered the part could be 3D printed.
Is this issue common or is it only mine? The original material looks to be a very soft plastic, on mine the retaining holes have collapsed - see photo
Thinking to do a set and replace all of them with a new part, not sure if later ones are the same but could probably do a set for them if different.
Any thoughts? Just a feeler at the moment
Sent from my SM-S901B using Tapatalk
Good shout. Half of mine have fallen apart as well. Would think that 3D printing would be the way to go (limited producion and all that). So yeah, do some ground work and let us know how you get on šŸ™‚
No worries
Has anyone got access to an early and late dash and can confirm they are the same or different?
James?  I believe the campaigns had the earlier interior.  Ever thought of changing to the late interior - i personally think it looks a lot better than the earlier, although the downside would be it wouldnt be the one it came with originally
Never crossed my mind to be honest. Like you say, it does look a little better, but originality is key on that one. The 8v Iā€™m not so precious about it being OE.
  On 6/20/2023 at 7:09 PM, Stone0311 said:
No worries
They are different, both visually and mechanically. Because of the later, horizontal bars, the fins are mounted directly into the housing. Removing the need for a link strip. A-la pre August 92 interiors.
Ɨ   Pasted as rich text.   Paste as plain text instead
Ɨ   Your link has been automatically embedded.   Display as a link instead
Ɨ   Your previous content has been restored.   Clear editor
Ɨ   You cannot paste images directly. Upload or insert images from URL.
Ɨ
Ɨ
