Neocorrado 0 Posted August 10, 2004 The rear fogs are not activeted for the US :mad: Corrados but i know they are for the Euro ones!!! does anyone have a pic of them on ? i wonna see what they look like cause i want to get mines activeted... Quote Share this post Link to post Share on other sites
KEVIN JAMES 0 Posted August 10, 2004 very easy just pop out the blank plastic bit over the l/h side fog light and stick a bulb in!! its all ready to go :) Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted August 10, 2004 Bear in mind the nearside rear fog has no metal heat deflector like the offside one has, so there is a risk of melting the plastic during prolonged use. You should be OK if you don't leave the fogs on for too long. Quote Share this post Link to post Share on other sites
daves16v 1 Posted August 10, 2004 I think the reflector is slightly different too. Quote Share this post Link to post Share on other sites
Neocorrado 0 Posted August 10, 2004 kevhaywire, what do you mean leave them on, is there a button for them only ? where do they come on ??? Quote Share this post Link to post Share on other sites
Supercharged 2 Posted August 10, 2004 They come on with the foglight button! Quote Share this post Link to post Share on other sites
Neocorrado 0 Posted August 10, 2004 Supercharged, Thanks alot :) so what do you think would be the limit to keep them on? 1, 2 ,3 hours ? Quote Share this post Link to post Share on other sites
Supercharged 2 Posted August 10, 2004 less than that... the later switches are better becuase there are seperate ones for front and back but then again the fronts also crack because of the intense heat :roll: Quote Share this post Link to post Share on other sites
Neocorrado 0 Posted August 10, 2004 Ya i know what you mean, i had changed my front ones before but they cracked again so i just leave them, what if i put a low voltage light bulb in it, would that help ? Quote Share this post Link to post Share on other sites
Henny 0 Posted August 10, 2004 you'd need a low WATTAGE bulb to reduce the heat... low Voltage would make it brighter/hotter and last lots less time... ;) Quote Share this post Link to post Share on other sites
Neocorrado 0 Posted August 11, 2004 Low wattage!!! got it :mrgreen: Quote Share this post Link to post Share on other sites
