Mike Edwards 0 Posted August 10, 2004 It had a new knock sensor 2 months ago and the loom seems okay. Optimax petrol being used. Anything in particular to check apart from the usual timingetc?i Quote Share this post Link to post Share on other sites
dr_mat 0 Posted August 10, 2004 That vac hose thing to the ECU seems to be the classic one... :) Quote Share this post Link to post Share on other sites
Henny 0 Posted August 10, 2004 also the blue temp sender... this normally causes overfuelling, but can also cause underfuelling if it fails in a slightly less normal way... I take it you've checked the resistance of the CO pot and that it's working OK? Quote Share this post Link to post Share on other sites
W3RKD 0 Posted August 10, 2004 mike have you got the correct w6dpo plugs in her ? Quote Share this post Link to post Share on other sites
kongo127 0 Posted August 10, 2004 Check the Knock Sensor harness back to the ECU. The knock sensor operates with very low voltages, it has no amp-op built in. So any damage in the wiring or even in corroded connectors are able to cause this situation. Also check for correct torque 15nm setting and 6º timing set for safe. What else upon all replys... :roll: Keep posting mate! We´re here to help! :D Quote Share this post Link to post Share on other sites
h100vw 0 Posted August 11, 2004 Does it occur all the time? Or is it a heat induced problem? Bearing in mind the high ambient temps we have seen recently. Gavin Quote Share this post Link to post Share on other sites
solomk1 0 Posted August 13, 2004 i seem to have the very same issue myself , i am new to the g60 game and this is my first problem,,i replaced the crank shells as ithought this was the problem but it seems to be a timing issue ( pinking ) i have a jabba stg 4 ,65mm,dcat super sprint ,jabba chip ,and unfortunatley no one seems to know how to set it up in the mids !!!! help cheers dale :wink: Quote Share this post Link to post Share on other sites
W3RKD 0 Posted August 13, 2004 i seem to have the very same issue myself , i am new to the g60 game and this is my first problem,,i replaced the crank shells as ithought this was the problem but it seems to be a timing issue ( pinking ) i have a jabba stg 4 ,65mm,dcat super sprint ,jabba chip ,and unfortunatley no one seems to know how to set it up in the mids !!!! help cheers dale :wink: see my above post .. also might be running a bit much advance.. u might also be needing w5dpo's with that spec. Quote Share this post Link to post Share on other sites
