dubweiser
What 2 do next ? HELP !!
Go easy on me cos i'm new here, but i'm having problems with my C idling and holding revs at bout 1500 revs.Hav done all the things such as changing plugs, leads ,rotor arm, dizzy cap, cleaned isv, and reset the computer but it still runs like bag 'o' sh**e.When the isv is unplugged it idles perfectly except slightly higher on't revs and tends to dive a bit after revving it up high.Took pipes of isv and it seems to be working.All the breather pipes look okay too.Anyone got any thoughts as to what to try next cos am going mad and got an itchy lighter hand !!!!
PLEEZ HELP !!!!!!!!!!!!!!!!!!!! :mad: :? :lol: :roll:
Do you mean the car idles at 1500? Seems awfully high to me if that's the case... Mine idles at about 900 - 950.
I had all manner of idle troubles when I got mine, the final cure involved a throttle switch and temprature sender (as dr_mat, rightly points out). I can dig up part no's if you need them.
The ISV could still be the problem, I guess (mine improved slightly with cleaning, but improved more when I slapped a new one in), unfortunately they're not cheap ,about £100 from euro car parts or German & Swedish.
Other possible candidates (clucthing at straws though) include a sticky throttle cable or blocked fuel filter.
I used to have an excellent article on fixing and adjusting 16V idles, only the link is dead now... :( if you have the patience you could try going through the VW FAQ for answers...
Failing that I'd get it to a Bosch Service Centre, they have all the diagnostic kit and won't charge the earth like a $tealer would.
LvP.
Update:
Just e-mailed the chap who was hosting the article (Andrew - Volkswizard) and he kindly e-mailed it back to me ;)
Admittedley this is aimed at the Golf 16V engines (i.e not the one that's in the 2.0) but it should hold true in most parts (I would expect...)
Firstly make sure the idle stabilisation valve is operating
normally.
With the ignition on position 2 (the instrument warning lights flashing
but
engine not running), the valve should buzz. You should be able to hear
it or
if not touch it and you should be able to feel it vibrating slightly.
If
this isn't happening then check the connection of the wiring plug.
Connecting a 12v directly to the valve should make the flap inside the
valve
open fully and should help distinguish if the problem lies with the
valve or
its wiring.
It is quite common for ISV's to become clogged up by oil vapours
from
the air that passes through them. This can make their action rather
lethargic meaning that the car wont maintain idle and instead will
stall e.g
when coasting to a stop. I had this problem on a 1990 Mk2 16v, it was
solved
by soaking the ISV overnight in petrol (carb cleaner is equally as good
but
costs more than £4 per gallon!) so it's worth trying if this sounds
familiar. Incidentally after the soaking period, the petrol was
significantly darker than previously confirming just how much gunk it
had
removed.
It's also worth fully unscrewing the idle bleed valve in the
throttle
body and cleaning it as well as all the inlet tracts and airflow flap.
The next step is to set the idle and CO. Mk2 16v's run best at
2.0% CO
which is significantly higher than the 1% +/- 0.5% recommended by the
factory. The added enrichment insures adequate fuelling when the 16v is
on
full song and is what the tuning companies aim for. When Ray Partner
last
took his famous red concours 16v that AmD had set-up for an MOT, the
tester
commented that it was running richer than normal. It passed though as
3.5%
is the upper limit for an MOT pass for a post 1986 car without a
catalyst.
I recently set the CO on my 1991 Jetta GTI 16v using the method
below
and when later rolling road tuned by Vince Saiya of Stealth Racing, the
reading was "spot on", so here goes;
With the engine fully warmed (above 80 degrees on MFA), turn off
the
engine and disconnect the white cased spade connector on the red and
black
lead from just to the left of the coil (click on thumbnail for a full
size
image).
This lead connects the coil to the idle stabilisation valve and
sends
an rpm based signal that determines the rate at which the ISV pulses
(the
duty cycle).
Disconnect the breather hose from the side of the airbox and
block the
hole. This should always be performed on most engines when setting the
mixture as it prevents crankcase gases being fed back into the engine
and
giving an untypically rich reading.
Start the engine and the idle revs should be lower than normal,
if
they aren't, the idle valve is not working properly and the idle speed
is
incorrectly being determined by the idle bypass screw alone.
With the engine running, turn the idle screw up until you get
950rpm
+-50.
If the idle wanders/hunts or is lumpy/misfires (engine visibly
rocking), insert your 3mm allen key into the CO adjustment screw in the
fuel
metering head and turn it anti-clockwise to weaken the mixture. Do not
rev
the engine with the 3mm allen key in position as you run a serious risk
of
damaging the airflow flap.
With the engine now idling very jerkily and just prior to the
engine
cutting out, turn the key clockwise in 1/8th turn increments until the
idle
smooths out. Eventually, the engine should settle to a nice, steady
idle
with no misfiring or jerking. This will be 2.0% or very close to it. If
the
revs have wandered away from 1000rpm in the meantime, adjust the idle
bleed
screw accordingly to restore them and return to adjusting the CO as
described above. When idle speed and CO are correctly adjusted, switch
off
the engine and reconnect the breather pipe and the red lead.
Take the car out for a run and when you dip the clutch, the rev
counter needle should gently fall to 1000rpm, not plummet. Also examine
the
exhaust gas, even at 2.0% there should not be any tell tale signs
suggesting
that the engine is running overly rich.
If after all that it's still missing and rough, investigate air
leaks
as these will cause the mixture to run lean and all the above will not
apply
until rectified.
If there is anything you are unsure about, take the car to your
local
Bosch agent for setting up, mine charges £25 + VAT or a rolling road
tune at
Stealth Racing is money well spent at £45 + VAT.
Thanks to Kevin Hayward and Gary Bocking of the excellent Club
GTI
e-list for these tips.
