Banana Man
Turbo conversion help required!!!
Has anyone converted they're G60 to turbo on her using the atp manifold as I am having clearance problems and no one seems to be able to tell me ways of getting round it without changing loads of parts and welding which I cant do! So if anyone can offer any advice it would be much appreciated.
Alternatively if you can give me a ring on 07740482464 and give me a few ideas that would be even better :)
cheers
Ant
If the turbo is hitting the bulkhead? then cut the front engine mount brakcet down and re weld it.
if it's hitting the cultch master cylinder, go get one off a TDI, or later corrado, it's shorter.
show some pics and what's hitting what exactly?
ok thanks for the info phat the supercharger engine is going back in for the moment now but I am still contemplating fitting the turbo engine at a later date it is now sitting back in the garrage for the moment!! :)
