Heardy 0 Posted September 15, 2004 Are gsf bushes anygood or should i just buy some from the main dealer? Also what sort of job to fit them ? Cheers jason Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted September 15, 2004 Mine came from GSF and they're fine. It's an easy job technically, but time consuming and labour intensive. Best done on a ramp to be honest, or some very high axle stands. The only caution I can advise is to press the new bushes in so that they are 8mm proud on the inboard side of the axle and make sure you align the bush correctly so that the passive steer function works. I've seen a couple of axle bush jobs where the bushes weren't pressed in correctly and the axle sat further to one side of the car than the other! K Quote Share this post Link to post Share on other sites
Heardy 0 Posted September 15, 2004 Looks like a job to do at work then,only got pit's though it's bit old fashioned ... Quote Share this post Link to post Share on other sites
Robbo149 0 Posted September 16, 2004 Yep, agree with Kev there, got my rear axle bushes from GSF & the difference was amazing! (original ones were shot though :wink: ) cheers, Robbo Quote Share this post Link to post Share on other sites
