monVR6
Vibration in gearbox - VR6
Just noticed the other day, when cruising in fourth, I can feel a "whirring" vibration through the gearstick/transmission tunnel - (vanishes when I change to 5th). Doesn't seem to match engine speed which confuses me - seems to sort of pulse every second! Any thoughts??
I have the same problem - in fourth.
I think I have heard someone else mentioning the same aswell. I've got used to it now and don't worry about it.... :roll:
That 33K old Storm I drove also did the same thing, just in 4th. It could be something to do with the cables rubbing on something which is only noticable when the linkage is in a certain position, i.e. 4th?
Place the car in 4th gear with the engine off and see if something is contacting the linkage. Otherwise, run my little test and report back.
R
