ving60
G60 idling probs when cold
When i come out after leaving the car stand e.g in the mornings an after work. I start the car an the idle is really low an it cuts out. I've cleaned the ISV with WD40 to no avail.
Sometimes also there's a pop from the exhaust.
It idles fine when it warms up.
Any suggestions :roll:
Sounds rather sensor related... like the blue or black temp senders perhaps, or the lambda? Can someone correct me if I am wrong.. I am trying to learn though...!
Check your wiring to your probe as sometime this can get damaged and caused these sort of problems.
If not the blue sender is a good bet too
