badlad1888
banging under car
I have just bought my second rado, a g60 and it has two problems
1. with someone in the back off the car, when you put the foot down it sounds like a hammer hitting the underside off the car at the rear.i had a look but everything looks ok, any ideas!
2. when i change gear above 5000rpm i can hear a high pitch chirping noise is this normal!
as you can guess i have no mechanical experience and need help!!!!! :oops:
1) exhaust banging on rear axle. car been lowered? get the exhaust mounts looked at!
2) take the sparrows out from under the driver's seat!!! ;)
ok i will get that checked out asap about the exhaust.
i am guessing the gasses escaping on the gear change is normal,i have owned the car a few weeks and never driven it hard until the weekend, then i heard the noise. :D
got to show the clio sport boys who is boss!!
The car hisses and whistles all the time when its had the boost return removed..
I think it must just be slightly tuned - every single G60 i've ever been in ALWAYS sounds different - you get all kinds of weird whistles, hisses, droans, etc etc depending on which car you go in! Mine makes a cool little whistle / dump valve kinda noise when you change up at quite high revs :D
Never enough room I find; and there always the risk of burning your arse on a hot zorst. :wink:
has it been lowered ?
sounds like tyres rubbing the rims or mudflaps scraping the ground or weak exhaust hangers ( rubbers )
just the xtra weight in the back makes the differance.
Note to self: Don't work on hot car :roll: :lol:
Banging under car
Be careful of gravel rash.
:lol: I was gonna say let the body out of the boot, but that works too ;)
Banging under car
9 useful/helpful replies to this and VR6 goes and lowers the tone of it :roll: :-P :-P :-P
the banging sounds like the exhaust flapping about
what are the engine mounts like?
if the front one is slack, just a little rock in the engine can send the pipe nuts
