vr6paul
handbrake adjustment?
Need to do this as far too many clicks.
Will be doing rear breaks anyway.
how straight forward is it to do?
thanks again
PAul
Paul,
You need to remove the trim from the centre tunnel inside the car behind the handbrake. There are a couple of adjusters there,.
John
Yep, but do that after you've overhauled the rear brakes. And remember, the rear wheels must lock with 3 clicks to pass the MOT now.
Fortunately you only need to show 16% of total (4-wheel) braking power at the rear wheels when using the handbrake to pass the MOT.. If it was made any more stringent, VW would suddenly have to start fitting proper rear handbrake mechanisms or something..! :)
There is a small tab underneath that has to be released, then slide the handle off at the same time. Can be a little tricky.
