vr6paul
strange vr6 starting problem- help!
Right i filled up with petrol tonight, jumped in the car, turned immobiliser off and turned key and all i got was ignition lights. It didn't turn over.
Got out to aimlessly look under the bonnet but could hear something turning whcih sounded like a fan or a pump but was too dark to see what.
During all this time the immobiliser would usually come back on but didnt'.
It was almost as if it thought the car was running?
after about 10mins the noise (turning fan or pump) stopped and the immobiliser cam back on.
Turned it off and turned the key and nothing.
Immobiliser back on again, switcked it off and it turned over and started.
Does this sould like a loose connection here?
If so where should i look?
Thanks in advance
the noise you can hear is the auxilary water pump,the problem could be with your alarm immobiliser or a faulty ignition switch
