SteveM16v 0 Posted October 15, 2004 Getting the horrible beeping coming on when above 3000 revs. The weird thing is, if I flick the main beam it stops (for a very short while). I've replaced the pressure switches but this hasn't solved the issue. Any ideas? Quote Share this post Link to post Share on other sites
Henny 0 Posted October 15, 2004 Are you sure that the oil pressure is correct on your engine? It could actually be that the beeping is coming on for the proper reason and you've just found an odd problem with your main beam! :| Otherwise, sounds like a dodgy earth somewhere to me... Quote Share this post Link to post Share on other sites
SteveM16v 0 Posted October 20, 2004 Thanks for the reply Henny. I don't think it can be the Oil pressure as its been happening for months now and I've been doing long motorway miles. I guess if it really was suffering I would have found out by now (knackered engine)???? The garage I'm taking it two on Tuesday think its electrical as its so intermittent (although it drove me mad this morning, stayed on solid for 20mins on the way to work) Is the garage right do you think? Quote Share this post Link to post Share on other sites
Henny 0 Posted October 20, 2004 yup, I'd go with a broken wire or a dodgy connector/ earth... 8) Quote Share this post Link to post Share on other sites
SteveM16v 0 Posted October 20, 2004 oh the relief, fantastic! Where might I find the broken wire/dodgy connector? might save the cost of the garage visit!! Thanks Quote Share this post Link to post Share on other sites
Henny 0 Posted October 20, 2004 anywhere from the switch back to the clocks... :| wiring's probably the most awkward thing to diagnose as there's so many daft things that can go wrong with it... :? Quote Share this post Link to post Share on other sites
SteveM16v 0 Posted October 20, 2004 arse, sounds like it could get very expensive. Oh well, cheaper than replacing the engine I guess! Quote Share this post Link to post Share on other sites
chubbybrown 0 Posted October 20, 2004 We used to bang the dashboard on top of the clocks with the mk1 golf and funnily enough the buzzer noise used to go away along with the worry ! :wink: Quote Share this post Link to post Share on other sites
