duffer 0 Posted October 28, 2004 Does anyone have an Ecotek (CB-26P) fitted to their Corrado, or used Ecoteks Power Boost spray? If so, did you notice any improvement? Would you recomend them? Quote Share this post Link to post Share on other sites
cheesy 0 Posted October 28, 2004 Theres a thread somewhere about this The ecoteks are a waste of money Quote Share this post Link to post Share on other sites
duffer 0 Posted October 28, 2004 Forget it. Just done a seach on here (should have done that first) and they appear to be rubbish. Does the spray work though? Quote Share this post Link to post Share on other sites
cheesy 0 Posted October 28, 2004 I've never used it soz Quote Share this post Link to post Share on other sites
samm_cvr6 0 Posted October 28, 2004 had one on my 205 (what came over me I do not know) they make a weird noise, at first I thought it was "quirky" but then began to think it was just crap. Not sure if it saved any fuel, if it did, it wasn't much. :wink: Quote Share this post Link to post Share on other sites
trebor 0 Posted November 21, 2004 The squeek factor on ecotek is awsome and mpg went up by 1mile per gallon... Liked the gold piperXcross filters... Cool Quote Share this post Link to post Share on other sites
PeterMunns 0 Posted November 21, 2004 My mate had one said no difference in power but did something for the mpg like what terbor says Quote Share this post Link to post Share on other sites
craigowl 0 Posted November 21, 2004 I think I saw a test somewhere which indicated that the aerosol spray stuff gave an improvement (measured instrumentally). I'm always afraid some of these things loosen up crusty old gunge that can cause a blockage somewhere. This belief, though, is only from reading things. I have not really heard of anyone actually being able to pinpoint blame on the products. Quote Share this post Link to post Share on other sites
trebor 0 Posted November 21, 2004 I went completely mad a few years ago ----bought the Power boost and that ecotek.. I can remember trying to convince a friend of mine (car mechanic). That these two products were amazing. He looked, read the instructions and laughed. Didnt believe him at the time :oops: Do now Quote Share this post Link to post Share on other sites
Neil VR6 0 Posted November 23, 2004 They just make the engine run lean dont they? (great for forced induction :shock: ) Quote Share this post Link to post Share on other sites
dr_mat 0 Posted November 23, 2004 I think they're supposed to help the injectors to provide a finer, more uniform mist, and therefore the engine can run leaner without pinking. The new direct-injection engines do something similar, very very finely controlled injector pattern allows them to burn in *part* of the cylinder without pinking, so it can run REALLY lean on overrun, and when coasting. Quote Share this post Link to post Share on other sites
aide 0 Posted November 23, 2004 The valve has an adjustable screw down pressure plate, which when vacume in manifold reaches required level (coasting, or overun) the pressure plate is forced open introducing additional air :shock: When open the valve introduces 'agitated' air which ecotek state burns better, whilst this is true to a degree, when considering the miniscule levels of air introduced it is actually bollocks - so yeh, it basically leans you out, makes a farting noise at traffic lights, intoduces a weakness in the brake servo system and cost £45 for the benefit - Whhooooppppeeee :D Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted November 23, 2004 I'm always afraid some of these things loosen up crusty old gunge that can cause a blockage somewhere. Crusty old grunge is a thing of the past now, thanks to modern engine oils and fuels. I wouldn't really use pour in chemicals as they play on the fact you can't actually see what's going on inside there and any improvements (if any) will just be in your mind. I know someone that used Redex continuously for about 5 years and his injectors siezed up! Quote Share this post Link to post Share on other sites
Tempest 0 Posted November 23, 2004 Same here: Tried the Powerboost spray on my then 19-year old DX engine in my Mk2 Storm Rocco, can't say it made any difference other than that one of the clips holding the downpipe to the manifold fell off shortly after :mad: That was probably not down to having used the Powerboost stuff. I then went on to try some injector cleaner on the poor Mk2 Storm Rocco DX-testbed (it was on special offer at my Oscotts car factor), again not noticing any real difference. Needless to say, I stopped using all of that stuff after one trial. Tempest Quote Share this post Link to post Share on other sites
