vr6 t
Quaife 6 speed 02a gearbox
I am about to purchase my second corrado the first bieng a 2.1 16v and the second one a vr6.My question is i have a 3 month old Quaife 6 speed and diff in a o2a gearbox which comes from a 1.8 16v corrado or a mk3 2.0 16v can the box be fitted on the vr
Cheers
the vr6 gearbox has a bigger bellhousing than the 4 cylinder boxes. you can swap the Quaife internals into a vr6 casing. All that will be needed is new diff bearings which will need to be pre loaded and the input and pinion shafts will need pre loading.
Lee
I sold my case and the unused internals back to Vince, so he should have a stock of 'em down at Stealth still... 8)
