surfer.vr6 0 Posted October 31, 2004 has anyone got any tips on how easy it is to change an o/s/f window motor the window is stuck up and it looks pretty difficult to get at also where is the best place (apart from vw dealers)to get one Quote Share this post Link to post Share on other sites
deag 0 Posted November 3, 2004 get one from scrappy, probably a passat will use the same part I've not removed one, but it looks pretty complex, because of the lack of access. deag. Quote Share this post Link to post Share on other sites
Colley 0 Posted November 3, 2004 I had mine go on my mk3 golf. Your have to take off the inside panelling. Its not to bad to do but you could do with someone helping you as you have to line up the window and make sure the cable is ok, as i said you could do it its just a bit tricky. Quote Share this post Link to post Share on other sites
