Jay_vr6 0 Posted November 14, 2004 Hi, Had a 95 vr6 corrado for about a month, just had a full service before i bought it and was running super fine. Now the thing keeps giving me trouble in first and second gear, the car judders something awful. Now all i can think of is some dodgy petrol or maybe water or crap in the tank from where i ran the petrol abit low. Could it be anything else and what the hell should i do!!! all help appreciated :) Quote Share this post Link to post Share on other sites
daveh 0 Posted November 14, 2004 My Corrado (16v) had running problems, which can be more noticable in the lower gears where the cars low momentum doesn't smooth things out. Other symptoms (for me) included. Problems starting. Engine occaisionally cut out. Revs die really low before recovering. Flat spot. Eventually traced to a dodgey distributor. Might be worth checking yours out. Dave. Quote Share this post Link to post Share on other sites
dr_mat 0 Posted November 14, 2004 95 VR6s don't have distributors. I'm guessing that the "trouble in 1st and 2nd gear" is a red herring, you have to assume it's running rough in general. Questions: does it idle well? does it pull well at full throttle? does it pull well at part load? When you say Judders, do you mean a judder relating to engine speed, or road speed? is it a judder you feel through the steering or the seat? is it noticeable in other gears, but much reduced? how does the engine behave off load? (i.e. in neutral if you rev it)? Quote Share this post Link to post Share on other sites
Neverite 0 Posted November 14, 2004 it sounds like you have exactly the same prob as me!... first gear pull away and i have to ride the clutch to actually stop it from 'roo'ing and accelerate reeeeeaaally carefully, into second much the same effect but not as full on, and once in third its ok.. you can still feel the engine behaving strangely but goes ok, (i assume its there in all gears but you feel less at higher speeds). after changing the air filter (not for this reason) it became less noticable (red herring again maybe?) but its still there. ive been told so many different things (lamda, fuel pump, dizzy and even the choke) from different ppl im just more confused now.. seems to idle fine, pulls well at part load, full throttle not the best response tbh ill let you know anything i find out jay, but at the mo im stumped p.s i beleive the judder jay is refering to is the kangaroo motion on pull away.. kind of like a learner driver pulling away for the first time(no jokes plz.. im sure we both know how to pull away properly) Quote Share this post Link to post Share on other sites
Jay_vr6 0 Posted November 14, 2004 Neverite has it exactly!!! starting to annoy me now Quote Share this post Link to post Share on other sites
Neverite 0 Posted November 14, 2004 its gonna be expensive... i can feel it. :cry: :cry: Quote Share this post Link to post Share on other sites
oxfordpaul 0 Posted November 14, 2004 I've just been through this very same problem and had been told it could be all sorts...changed the leads (a common fault - are they the originals, if so start with these), to no avail, then the coil pack (another common fault but expensive) and that made no difference. The fault was the spark plugs...i had paid for a full 20k service when i bought the car in June which should include plugs. Fact is, the garage didn't change the plugs as i found out last week and a new set was then fitted which has completely cured it!!! So start with plugs, then leads, then coil pack. If you're any where near Oxford I have my old coil pack which you could try and the leads which were fine to use as a process of elimination. Quote Share this post Link to post Share on other sites
Neverite 0 Posted November 14, 2004 thanks paul... day off work tommorrow then and first thing on the agenda :D Quote Share this post Link to post Share on other sites
Jay_vr6 0 Posted November 14, 2004 where is th ebest place for spark plugs ? best to just get vw standard jobs or worth spending a little more ? Quote Share this post Link to post Share on other sites
oxfordpaul 0 Posted November 14, 2004 I got NGK ones from http://www.sparkplugs.co.uk - free postage too - £26ish for 6. however, the garage snapped one in half when fitting and he recommended Bosch ones which have a thicker core. I only do low miles as it's a second car and have always heard good things about NGK so I still reckon thats your best bet. Quote Share this post Link to post Share on other sites
dr_mat 0 Posted November 14, 2004 Not wishing to scare anyone, but I had similar driving symptoms once in a transit van with a blown head gasket... Running on three cylinders makes the engine very juddery and prone to stalling.. But most likely it's just a spark problem.. ;) Quote Share this post Link to post Share on other sites
vr6storm 0 Posted November 14, 2004 NGK plugs are also meant to be able to withstand the heat generated by the VR6 better than others :wink: Quote Share this post Link to post Share on other sites
Jay_vr6 0 Posted November 17, 2004 1 litre of injector cleaner and the cars running almost perfect again, getting my mechanic friend to look at the spark plugs and leads tommorrow. Quote Share this post Link to post Share on other sites
GIXXERUK 0 Posted November 17, 2004 Jay_vr6, let us know how you get on , better to know the cure before the problem occurs :wink: Quote Share this post Link to post Share on other sites
Roger Blassberg 0 Posted November 18, 2004 I read somewhere that it is advisable to change the oil after using injector cleaner in the fuel - maybe a bit neurotic, but passed on in good faith. Best wishes RB Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted November 18, 2004 NGK plugs are also meant to be able to withstand the heat generated by the VR6 better than others :wink: That's codswallop mate... who told you that? NGK are probably able to supply them cheaper to the dealers than other brands! I've used Bosch plugs and not had any issues with those.... in fact they last longer than the NGKs :wink: Quote Share this post Link to post Share on other sites
Jay_vr6 0 Posted November 18, 2004 well the oil is only 400 miles old so I'm not sending it in to be re done, I've never had any probs with my other cars and dare I say the name I had a sweet tuned vauxhall astra and that was ok after a tank full of the stuff, but as you say it wouldn't hurt but as my cash is dwindling I'll leave it a while and see if anything occurs :) Quote Share this post Link to post Share on other sites
vr6storm 0 Posted November 18, 2004 NGK plugs are also meant to be able to withstand the heat generated by the VR6 better than others :wink: That's codswallop mate... who told you that? NGK are probably able to supply them cheaper to the dealers than other brands! I've used Bosch plugs and not had any issues with those.... in fact they last longer than the NGKs :wink: thats what the CCGB tech guru told me matey :wink:.....so there :lol: :D :wink: Quote Share this post Link to post Share on other sites
