RACK
Spark Plugs
Just been having a quick think.
Would I be better of using W5DPO plugs instead of my current W6DPO's?
My Current spec is;
68mm pulley, Jabba Chip, Golf IC, Ported Charger, Jetex Cone, Full SS exhaust, boost return mod and check valve.
Anyone got any views?
Thanks
RACK
Way cheaper from here http://www.spark-plug.co.uk/
do a part search on a bp5et which is a grade colder than standard if Im right. @£3.20
and if you do a x-ref there is a few other options.
Or there is a race spac plug listed in x-ref to the stock bp6et as a NGK BP6EV Gold palladium centre @ £4.98
HTH
what spark to use for PG (without g60, but motor with turbo) motor with turbo conversion? Please suggest. Thanks
