Neil VR6
JMR
A massive thanks to John at JMR for all the work that he's done on my car.
Parts:
Rear axle suspension bushes x2
2 litres of brake fluid
Mk 3 Golf OSR brake caliper
Rear brake compensator valve
Hydraulic clutch slave cylinder
Brake/clutch fluid transfer hose
JMR solid billet alloy front engine mount
5 litres of Synta Silver oil
Oil filter
Lupo wipers f&r
JMR oil cooler kit (Mocal)
JMR supercharger alloy outlet kit
Miltek exhaust and cat bypass
Exhaust gasket
Odds and s0ds
Work Completed
Fitted above
Hydraulic fluid changes
Gear shift cables adjusted (for optimum rifle bolt gear shift!)
Drivers door adjusted to sit flush
I'm now absolutely skint but the car is transformed. Gear shift and power delivery are fantastic due to the engine mount and gear adjustment. It pulls like a train in high gears from 20mph and sounds like a WW2 fighter plane. Following the alloy outlet and removal of some silencing expansion box the S/C really sings too. The back end is stable following the rear bush replacement and even the handbrake works now!
It feels like a different car to the one I took down there a couple of weeks ago! :D :D :D
I can't recommend JMR enough if you want great service and top quality parts.
Ah another Neil....
Mine is at JMR also getting the rear axle bushes, mk4 rear brakes, hoses, front ball joints/drop link and a good old check over.
Was yours the blue one with the 15" bbs by the garage? very nice if so! a nice Rallye inside also!
dropped mine off on sat.
I'm missing the old girl already but can't wait till it's out!!!
Yup, that was mine! There was a black VR there yesterday and the Rallye was under covers. It was in for a new charger, waiting on bits! Whilst I was there, two other 'Rado's turned up as well including the chap who I bought the BBS's off! Small world! You won't be disappointed! The rear bushes made an amazing difference, the car feels so much more stable.
