Chris M 0 Posted December 14, 2004 Hi, I'm trying to get my head around this passive rear beam bush malarky after owning a couple of mk1's and a mk2 i'm not sure if i just need to get used to the fact the the backend does more that just get draged around but so far i don't like it, so i've decided to replace the bushes for new ones to see if they are worn (after 120K) and moving too much. i've looked on etka for the part number and it apears to be the same as the mk2 items (191 501 541) and also spoke to the guys at euro car parts and found the same? can any one shed any light on what the difference is or am i just looking at the wrong bush. i need to sort this soon because christmas week is going to be the only time i will get chance to work on it. oh its a 91 g60 thanks, chris. Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted December 14, 2004 If you don't like the way the rear end feels, the bushes are definitely knackered. They usually are by 120K. Mine were starting to split at 85K. The Corrado bush is different from the MK2 item, so they're telling you wrong. Try Stealth Racing as they always know what stuff to use, or try a search on here as the part numbers have been mentioned before in similar posts. The corrado bushes have 2 little 'cut out' bits in the bush which provide the flexing. MK2 ones are solid. Quote Share this post Link to post Share on other sites
Rossco 0 Posted December 15, 2004 Any idea on costs?? Quote Share this post Link to post Share on other sites
16VG60 1 Posted December 15, 2004 The part no. for the rear beam bushes as fitted to the G60 is 191 501 541 and they are £32.70 each from VW. Quote Share this post Link to post Share on other sites
Chris M 0 Posted December 15, 2004 yes thats the same part number i found on Etka but it is the same part number as the mk2 beam bushes on Etka Quote Share this post Link to post Share on other sites
exturbo2003 0 Posted December 19, 2004 i cant find my reciept but kev's right they are differant Quote Share this post Link to post Share on other sites
Supercharged 2 Posted December 19, 2004 The VR's use the MK3 part 1HO ........... Quote Share this post Link to post Share on other sites
