pixie 0 Posted December 25, 2004 hi all merry xmass, i am having a wee bit of trouble with my vr6 conversion i have got to the point now where i need to fire the engine up! I have given power to the engine loom and when i turn the keys the engine turns over fine but there is no spark coming from the plugs! i have checked the coil and this seems to be getting power fine! what else could be naking the car not to spark? mailto:[email protected] cheers Pixie Quote Share this post Link to post Share on other sites
Jim 2 Posted December 25, 2004 I'm pretty crap at this techie stuff and I am frequently reminded of this fact, but as no-one is around i'm willing to have a quick stab.. apologies if you already know about this stuff! You don't happen to have a VR6 engine and ECU from a 1995 or newer car do you? Could it be related to the 'inbuilt' immboliser based off a transponder chip in the keys? Have you got the firing order right? Er... thats about as much as I can think of! Quote Share this post Link to post Share on other sites
kongo127 0 Posted December 25, 2004 Yeah... I´m not a good help on those VR6 engines too... But you only need to check to items: 1st - Coil 12v supplied? 2nd - Does the coil receive the timing signal from the ECU to spark? Well... It´s probably not that simple. :wink: But i assume that an engine with fuel and spark plugs firing must run. Are there any vital sensors to the ECU so that can immobilise it? :?: Keep posting mate! :) Quote Share this post Link to post Share on other sites
Craigs8vgti 0 Posted December 26, 2004 The person you nee talk to is phatsvr6 he the guy about vrs Quote Share this post Link to post Share on other sites
pixie 0 Posted December 26, 2004 hi all thanks for the advise! the coil is getting a supply not sure about the timing signal! the car is pre 95 no imobliser when i turn the key the engine turns over and trys to start but there is no spark from any of the plugs! cheers Dave Quote Share this post Link to post Share on other sites
dr_mat 0 Posted December 27, 2004 Do you have VAGCOM plugged into the diags port? Can you scan for codes? Most likely candidates for "no spark" are: - engine position sensor on block - immobiliser (built-in or aftermarket) - ecu relays (109) - coil pack feeds It's unlikely that the coil pack will lose all SIX outputs at once, so I'd say it's likely to be one of the former. Check that relay first. Quote Share this post Link to post Share on other sites
pixie 0 Posted December 27, 2004 cheers lads dr_matt you hit the nail on the head! cheacked 109 and found it not to be full in correct and also found a couple more rouge wires at the back of the fuse board and hey presto we have a spark!! cheers lads :) Quote Share this post Link to post Share on other sites
Bobby 0 Posted December 28, 2004 Bit off topic, but how long did it take you to do the converson and what model mk2 is it? Quote Share this post Link to post Share on other sites
PhatVR6 0 Posted December 28, 2004 Is it all sorted now? sorry. missed the thread earlier. Quote Share this post Link to post Share on other sites
pixie 0 Posted December 29, 2004 bobby, i have had the car for about a year doing it up slowly i might add! its just my prodject i just put money into when i have it but make sure its good qualit parts im using like vibra monts etc! but if you had the cash! and the parts and probably more cash and a few mates willing to help you out i would think it would take a few weeks! my mate who is doing the conversion thinks if i had all the parts there for him he would be able to do it in a weekend! lol but i think he would be pushing it a bit! but i call his bluff soon when i want to reshell the golf lol! Quote Share this post Link to post Share on other sites
PhatVR6 0 Posted December 29, 2004 nah, it's possible in a weekend, I've done 2 on my driveway! Quote Share this post Link to post Share on other sites
pixie 0 Posted December 30, 2004 sweet! i wish i had a drive way! trying to get it done inside a garage but you dont even have enough room to open the doors! but she is getting there Quote Share this post Link to post Share on other sites
