kongo127
Need more grip!
My Rado is running like a dream! :D
The wheels are spinning everytime i run at full throtle!
Even in 3rd gear! :shock:
To much power loss... :wink:
I am looking for a nice set of shock absorvers + springs for a nice price.
What do you recommend?
Any good experiences?
Should i go for a 40mm drop as well?
Opinions needed! :-P
Even in 3rd gear! Shocked
Meh, only in third or below, whats the problem?
Have you checked tyre pressures (I assume you've got good tyres) had the geometry checked, new bushes, reasonable fresh shocks springs on already? Changing the suspension for aftermarket stuff will always see an improvement over 10 year old standard stuff, even though fresh standard stuff may well be exactly what you need. Bear in mind its slippy out there and FWD was never the best for putting the power down.
Yeah...
The problem is that i don´t know the age of my suspension... :?
But spinning in 3rd gear is normal? Yahoo! :cheers:
What a ride! :D
I will probably go for any german material... 8)
when i put my eip solid front mount into my raddo i found that the traction was improved a bit might be woth givin a go mate! :D
