Rossco
G60 Lambda probe
I was just looking at my lambda probe and it bracket today, interesting bit of kit on the bracket there appears to be a bit of a connector like and earth bolted to it but its snapped off, anyone know where this could be from??? Also the earth for the lamba probe itself, where abouts is this usually bolted to????
Cheers
Ross
Hi
The earth bolts from the harness to the top of the engine mount. This earth is important. the o2 operation wont work if its not connected/snapped.
these tend to snap when the engine mounts are on their way out.
do a wobble test on the other wires at the plug and check they are ok. these tend to get brittle and break.
as in?
on the probe side of the harness there is 3 wires coming out back to the probe in the pipe. there were 4 originially the one missing is the snapped earth. 4 wires come out engine side on the loom.
IIRC the far right wire is the signal for the probe, the 2 white (probe side) are for the heating system in the probe, brown is earth
