Nick_Micouris
Brake fluid - quantity
and i'll have the rest!
Bleeding the brakes you dont need much probably about a litre would do. Make sure the resevoir is doesnt go empty while your bleeding the system, are you going to do the clutch too?
I did the brake fluid on mine last weekend when I was fitting a new Clutch Master Cylinder. Took nearly 1 litre. I used ATE dot 4 fluid from ECP.
belfastfumanchu The fluid on yours was replaced when I had the master cylinder changed on it. Look through the receipts you got with the car to see how long ago that was. There'll be a receipt for the master cylinder from ECP and another receipt from VW for fitting it.
Think a fluid change should be every 2 years unless you're using DOT 5.1 and doing lots of trackdays.
be careful when bleeding the brakes, the master cylinder MAY go as it`s not used to being pushed through it`s full range as i found out on my way back from the garage a couple of weeks ago!
