potatonet 0 Posted January 9, 2005 I want to set up an oil pressure gauge for my oil system so that I can monitor what my psi is. How do I set up the adapter for my system on my G60 cause I have no idea how to do it other than the side of the head. I dont have the stock oil cooler anymore, I recently removed it and changed out the hoses and system to run into a radiator style cooler, much more efficient for oil and water. Quote Share this post Link to post Share on other sites
Fat Tony 0 Posted January 10, 2005 Mines is in at the side of the head. I'm not sure I understand why you'd want to put it somewhere else or is it because of the cooler Quote Share this post Link to post Share on other sites
potatonet 0 Posted January 11, 2005 does your pressure sensor go off or how is it attached to the end of the head? Quote Share this post Link to post Share on other sites
Fat Tony 0 Posted January 11, 2005 it screws into the temprature sensor (i think) on the right hand side of the block. I can take a picture if you wish. Quote Share this post Link to post Share on other sites
Fat Tony 0 Posted January 11, 2005 Here we go Quote Share this post Link to post Share on other sites
potatonet 0 Posted January 11, 2005 pic didnt flash. e-mail me at mailto:[email protected] Quote Share this post Link to post Share on other sites
Guest Posted January 11, 2005 problem with using the side of the head on a G is you already have to feeds coming from there-Charger supply and .2bar ? I think oil sender. Take the sender out oil buzzer will piss you off very quickly, unless you take that off too. dunno if there is such a thing, but a 3 way spliter? like a t-piece.. where do you have your temp and other oil sender? one that was on stock cooler? Quote Share this post Link to post Share on other sites
Rossco 0 Posted January 11, 2005 what ive done is went to VW and bought another bolt and take off piece the same as the ones that the sender is sitting in as standard and the bolt that goes through it so ive got both connected, if you dont understand(i dont blame you) then ill fire up a pic for you Quote Share this post Link to post Share on other sites
