biggerbigben 0 Posted January 14, 2005 Hi Guys, Not planning anything quite yet but just doing my research. If I got hold of a V6 4-motion haldex set up I beleive the gearbox wouldn't fit my 20v engine, however if I managed to source a 20v haldex gearbox and use the gearbox bellhousing from the 20v box to put the V6 gears into would this be compatible and thus do the job???? Any ideas..... :?: :D Coxylad, PhatVR6... you guys might know? Quote Share this post Link to post Share on other sites
PhatVR6 0 Posted January 14, 2005 yes. you may need a tt bellhousing though. Quote Share this post Link to post Share on other sites
Mike Edwards 0 Posted January 14, 2005 Does this mean you'll have a 4-motion engine going spare??? Phat - how do you go about fitting one of these things again? Quote Share this post Link to post Share on other sites
PhatVR6 0 Posted January 14, 2005 the 02m is a complete bastard to fit in an older vw. The thing is huge, and runs VERY close to the subframe. firstt of all, your driveshafts ain't gonna fit, so it's time for shortened TT ones or custom ones. secondly, the bigger TT CV joints mean that th gearbox side subframe mounth as to go altogether or be moved back. so you have to make up a cutsom mount or weld in the chassis leg mounts like in a mk4 golf or tt. and also, there is no provision to bolt on the front engine mount either, so it's another custom jobbie. also, those dual mass flywheels are total sh1t and fail a lot. i have a few of those if you need one. one of the reasons I decided not to fit the 02m in my corrado. it'll be going in my golf, but that won't exactly be shy of chassis mods.......... check out http://www.dutchdub.com for more info on getting the 02m in. Quote Share this post Link to post Share on other sites
Mike Edwards 0 Posted January 14, 2005 So your recommended engine is??? Quote Share this post Link to post Share on other sites
PhatVR6 0 Posted January 14, 2005 24v VR all the way. Quote Share this post Link to post Share on other sites
biggerbigben 0 Posted January 14, 2005 decided against the move to 4-motion this evening because I can't afford it at the moment. Need to get the car on the road... thanks for the help phat.. Quote Share this post Link to post Share on other sites
CoxyLaad 0 Posted January 16, 2005 I have done the 02M installation on my old mk2, and it was a bit of a fiddly job, with a few custom brackets to be made up, but its not horrific by anymeans, it is an engine out, subframe off job though. The corrado I have is using the mk4 engine mounting system, so the 02m just hangs there nicely. Quote Share this post Link to post Share on other sites
MelG60 0 Posted January 16, 2005 What driveshafts did you use in the 02M mk2 Golf Coxylaad? Did you shorten the 02M ones? Quote Share this post Link to post Share on other sites
CoxyLaad 0 Posted January 16, 2005 yeah, I had them friction welded the correct length cos I wanted the chunkier cvs. I would only have shafts shortened by friction welding and no other way, the consequences of one of those giving out at speed could be catastrophic Quote Share this post Link to post Share on other sites
MelG60 0 Posted January 17, 2005 Thnx for the info. Btw BiggerBigBen: if you use the 02M gearbox remember you have to buy a new clutch and have a one mass 240mm flywheel made as the oem dualmass is too weak also be sure to get the starter with it. Quote Share this post Link to post Share on other sites
biggerbigben 0 Posted January 18, 2005 Thnx for the info. Btw BiggerBigBen: if you use the 02M gearbox remember you have to buy a new clutch and have a one mass 240mm flywheel made as the oem dualmass is too weak also be sure to get the starter with it. Thus why I can't afford to do it yet... watch this space though... Quote Share this post Link to post Share on other sites
PhatVR6 0 Posted January 19, 2005 I have an R32 clutch if you want to buy that? My mate has a flywheel off an audi A3, i'll see if they fit together with the 02m box, they should do. Quote Share this post Link to post Share on other sites
biggerbigben 0 Posted January 20, 2005 Phat, Thats kind of you to offer but I just can't afford to do it, besides I think its more important to get the car on the road.... If I did it I would want a decent clutch as the R32 one isn't that good, I've been in Guy H's AMD tuned 300bhp R32 and his clutch slips all the time when you floor it! There might not be any after market ones avaliable at the moment, who knows.. I'll leave this conversion untill end of the year I think... maybe with a change of engine as well?!!? Quote Share this post Link to post Share on other sites
