MLPVR6 0 Posted January 17, 2005 Morning. On a couple of occasions recently my VR6 has beeped at me when going quickly round a bend. Is that telling me that the traction control has taken action?? Ta Quote Share this post Link to post Share on other sites
Henny 0 Posted January 17, 2005 nope, it's more likely telling you to check your oil level... ;) The only warning beeper on a Corrado is the low oil pressure warning. Quote Share this post Link to post Share on other sites
MLPVR6 0 Posted January 17, 2005 didn't think that the traction control would be either that advanced or that annoying. hmmm, oil pressure. something else to keep my eye on I suppose. Presumably reasonable driving forces shouldn't impact it that much. I will investigate. Thanks. Quote Share this post Link to post Share on other sites
Louie Lungbubble 0 Posted January 17, 2005 Been discussed a few times before, this mate. More often than not it's the white oil pressure switch / sensor losing the plot when a bit of lateral G gets a hold of it. Same was happening on mine. Don't rely on it though. you never know. Could be a warning of something ugly about to happen with the oil pump! :wink: Quote Share this post Link to post Share on other sites
Jim 2 Posted January 17, 2005 Its more likely to be your oil level being a bit low.. check the level out and top it up! :) Quote Share this post Link to post Share on other sites
Louie Lungbubble 0 Posted January 17, 2005 Ha ha... Yeah, should've put that. The above is assuming your oil levels are ok in the first place! :oops: Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted January 17, 2005 Running low oil round sharp bends can lead to wrecked big ends if you're unlucky. Only takes a couple of seconds of dry running to feck em up. That's generally what the oil buzzer is telling you.....an oil surge has taken place.... Make sure you keep the dipstick at MAX all the time. Quote Share this post Link to post Share on other sites
MLPVR6 0 Posted January 17, 2005 will do. Thanks. anyone reccomend any particular grade / brand of oil? Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted January 17, 2005 The standard silver Quantum stuff VW sell seems to do the trick :D Quote Share this post Link to post Share on other sites
