B17 G60
Corrado 2.0 16v box into mk2 golf 16v?
Just a general question really, do the corrado 2.0 16v gearbox's which i think are cable operated fit 1.8 mk2 golf 16v's?
also any places in london area that will replace the diff bolts on a 16v box and the 1st an 2nd gear syncrho's?
cheers peeps :wink:
cheers peeps :wink:
It'll fit, cause the G60 golf had the cable change O2A box, but you'll need a passat clutch release lever in place of the corrado slave cylinder (hydraulic in most passats and all C's) unless you fit the corrado hydraulic stuff and all the gear lever gubbins and the cables. Can be done though, the O2A box is stronger but most don't like the feel over the rod operated mk2 boxes.
David.
you can use the seat cable clutch adapter too and then all you need id the cable gear selector and the box
