mariovr6
white blob
o NO
yesterday after a very short drive i looked at under the oil cap and what did i find?? a white drop on it!!!! can this only mean one the?? water on the oil cap?? it didnt appear later when i checked !!!
ave i blown the head?
other problems it has is a slight water leak like 1once a week it needs a top up even after i changed the bottle n cap !!!
it leak abit from the therm housing ( got parts to change for that)
but also its leaking out the top of the bottle not from the lid though like it might be blowing it out
could this just be air lock?
could the white water be oil cooler or just wishful thinking?
Milk shake on the oil cap does not always mean your hear is blown, if you got milk shake on your dip stick it does!
after a longer journey there is no sign of milkshake n the oil cap,but only noticed the milkshake yesterday, aftera short journey for the first time.
The dip stick is clean and no white but it always shows max oil.
Could the water leak be connected to the problem?
If you don't get any milkshake on the cap after a long drive and there's none on the dipstick then it's fine.
A water leak is unlikely to be related, but it depends on what is leaking where...
I'd sort the thermostat housing leak first, that is a known fault.
You need to find there the water is leaking from at the header tank.
Possibilities:
1. Cap pressure release - Is it operating correctly? i.e. is it damaged and releasing early or is the pressure building too much and the cap is having to release it.
2. Cap to tank seal - Is this making a good seal, make sure all mating parts are clean and the rubber 'O' ring is in good condition.
3. Damage to cap - Examine for cracks etc.
4. Damage to tank - Examine for cracks etc.
5. Leaks around connecting hoses and sensor.
While you have leaks you will need to top the water up. Fix them and take it from there. Once it is leak free, if it still uses water, it suggests futher investigation of the engine is needed. Most garages have a sniffer which tests for head gasket problems. Might be worth getting that done.
i dont think the leak is the bottle or cap cos there both new!!
there is presure when hot if you squeeze the hoses theres no give until it cools down....
could a airlock be the reason for it comimg out the bottle?? water still turns a rusty colour when the pink coolent gets old
...... if you got milk shake on your dip stick it does!
That sounds more like medical advice.
:lol:
